HuckleberryHunt's avatar
Jul 09, 2018
Added a battery tray
On our new ORV, I wanted to place two GRP 27 batteries on the tongue, but they'd only fit in the designated spot if they were not in battery boxes, so I spent some time over the weekend making a removable bracket that would allow both boxes to fit.
The bracket is made entirely from an old bed frame, which I cut up and welded together. I welded a couple bolts to the bottom and created a clamp that secures it to the existing channel.
The thing turned out even better than anticipated.
by
by
  • Thanks All. It was a fun project.
    RoyB wrote:
    I am currently planning on installing a TORKLIFT battery box that is 59-inch wide using those same welded on angles and this will stick out across the tongue area over a foot or so on each side... This box will align up with the second upright wall section on the front deck on both sides in the above photo. If this doesn't look good to me for support of the box I will have to put different angles in place on top of the tongue area.
    I believe it will be OK for me however... The TORKLIFT box fits perfect inside the two welded on angle sections...
    You will be facing the same problem if you ever want to increase to more batteries in the future...
    Roy Ken
    This should get us through the next 5-6 years I hope (expected lifespan of the batteries).
    We currently don't do a ton of boon docking, but do like to get out for up to 5-6 days at a time, so with the generator and possibly a solar panel in the future, this should do. In the future I'd like to swap out to 6v GC batts or true deep cycle batteries, so will tackle that when the time comes. I could probably do like you and make a reinforced bracket that sits on top of the frame rails to house a large pre-fabed battery box. When that time comes though I'm also planning on ditching the stock WFCO converter/charger for a better model as well to help protect/maintain my investment.
    PS. I had a similar setup on our last trailer with two equally speced batteries. There must be more parasitic draw from the electronics in this trailer (which doesn't surprise me!) because overnight it pulls the batteries voltage down well below what our old one did (I knew our old one inside and out). I have not spent time yet measuring out and diagnosing what/where the loads on this one ares though. TBD!
  • RoyB's avatar
    RoyB
    Explorer III
    Nice Work... Thanks for the tip of using discarded bed frames. I have one of those leaning up against a wall here...
    My tongue area already has two angle sections welded across the tongue area and I have had three GP24 battery boxes using those angles. They stuck out just an inch or so on either side.
    Roy's image
    Google Image
    Roy Ken
  • Two G29's wouldn't fit on our trailer either. I made a longer tray and mounted it over the frame rails above the stock tray.
  • ScottG wrote:
    No pic. You'll need to use a hosting site.
    I'm working on it...
    ....and finished.
  • No pic. You'll need to use a hosting site.
    (and we wanna see your project!)
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
