tenbear
Jul 02, 2012Explorer
helperzack wrote:
Snip...
Are there any special requirements on the 120VAC meter?
The last I knew there were 2 kinds of 120vac meters, one required a 12v power supply to power the meter, the other uses the 120vac that is being measured to power the meter. I recommend the self powering type even though you won't be able to measure low voltages, but who cares. The 12v power type may require that the 12 V is isolated from the ac being measured which may be difficult in the RV. It also requires 2 more wires.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
