NetBoy's avatar
NetBoy
Adding a Digital Volt Meter to show battery state of charge
Hi, I decided to add a digital volt meter to my motorhome to show the state of charge of the batteries - it will be handy when dry camping.
Here is a table from the web site "The 12 Volt Side of Life" that shows voltage vs state of charge (a great web site to learn about living on 12 volts):
I ordered a digital volt meter from eBay for $5 including shipping:
I mounted the meter, and a momentary contact switch, in a piece of plastic from an old car litter basket:
I will mount the meter in some convenient location in the motorhome tomorrow. And I'll include a printout of the above voltage chart.
Pretty cool for five bucks!
Note that battery voltage should be read when the batteries are at "rest" -- that is, wait a half hour after any big discharge (for example, such as running a microwave on an inverter).
  • I did the same thing but added a 120VAC meter with it to monitor shore power--I very seldom dry camp.
    Here's my setup:
    (I wasn't plugged in to shore power when I took the pic so top meter is dark).
  • Hi NetBoy, great minds think alike, etc. Having a voltmeter is a great help when camping without electric hookup.
    Here is where I installed my battery monitor some time ago. The switch below the meter is a SPDT to select either the converter output or the battery voltage. Since then I also installed a 120vac meter.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
