SJ-Chris
Mar 04, 2021Explorer II
2112 wrote:
Use a vented box and hose. THIS May provide some ideas. See the 2 white boxes with the black vent hose.
HERE is a wall mount vent. See the Frequently Bought Together section
I found that article to be interesting. On the one hand, it talked about the seriousness (...and explosions), and on the other hand they seem to conclude with this: "Although it sounds fancy, and rather technical – venting an RV battery is not quite as complex as it sounds. All you really need to do is add a few holes – about 25mm in diameter to the top and bottom of your battery enclosure. It’s a simple enough procedure and it could prevent a disaster."
Does anyone know what impact gassing/etc might have on other belongings stored in the same compartment?
Thanks!
Chris
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
