SJ-Chris
Mar 05, 2021Explorer II
SJ-Chris wrote:drgslayr wrote:
We had a Majestic 24a. When I added an extra battery we didnt have the storage space to loose so I added one of these.
We went with AGM so we didn't have to worry about adding water or anything else.
https://www.torklift.com/rv/hiddenpower.
That is a very interesting option which I had not thought about....THANKS for the suggestion.
I did some more searching around and found this also:
https://www.amazon.com/Steel-Bolt-Battery-Mounting-Tray/dp/B076666P81/ref=pd_aw_sbs_1/144-3145342-8767014?_encoding=UTF8&pd_rd_i=B076666P81&pd_rd_r=f1726189-410c-4871-b170-b3d24a36a906&pd_rd_w=BEsmu&pd_rd_wg=CqbHc&pf_rd_p=1b60d0cd-e691-440f-aa83-cc788b983d0c&pf_rd_r=WHJTWV7J842SEVSR758V&psc=1&refRID=WHJTWV7J842SEVSR758V
I'll have to crawl under my RV and see if there is a convenient place for something like this. The one drawback I see is access....seems like it would be a tremendous hassle anytime the battery needed to be checked/maintained/etc. If I was able to mount such a bracket, I'm not entirely sure how I'd be able to lift the battery up into it.
-Chris
The torklift solution looks like it costs over $200. Would be nice to find a less expensive solution.
This looked like a good solution (I like all the mounting holes), but it isn't big enough for a Group 29 battery: $48
https://www.amazon.com/Steel-Bolt-Battery-Mounting-Tray/dp/B076666P81/ref=pd_sbs_1?pd_rd_w=0sM5W&pf_rd_p=527ea27c-adf6-4b67-9c5f-265eb29e0622&pf_rd_r=ABK60C0DF1AWM22PBZ97&pd_rd_r=51e07f18-ddeb-415c-b1a6-a27605c30b6c&pd_rd_wg=sYElr&pd_rd_i=B076666P81&psc=1
Has anyone seen something similar that will fit a Group 29 battery? (Group 29 battery is 13" long by 6.75" deep by 8.5" tall). This is really the style I'd like to find.
I googled for a bit and found this: $89
https://www.steinertractor.com/OLS035?crawlparam&gclid=EAIaIQobChMIgdXbgpub7wIVpCGtBh0HfgxOEAYYByABEgLjgfD_BwE
Looks like it could work, but would require drilling several mounting holes through the back plate. Should be doable.
Gonna keep looking though...
-Chris
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
