drgslayr
Mar 08, 2021Explorer
SJ-Chris wrote:drgslayr wrote:
We had a Majestic 24a. When I added an extra battery we didnt have the storage space to loose so I added one of these.
We went with AGM so we didn't have to worry about adding water or anything else.
https://www.torklift.com/rv/hiddenpower.
That is a very interesting option which I had not thought about....THANKS for the suggestion.
I did some more searching around and found this also:
https://www.amazon.com/Steel-Bolt-Battery-Mounting-Tray/dp/B076666P81/ref=pd_aw_sbs_1/144-3145342-8767014?_encoding=UTF8&pd_rd_i=B076666P81&pd_rd_r=f1726189-410c-4871-b170-b3d24a36a906&pd_rd_w=BEsmu&pd_rd_wg=CqbHc&pf_rd_p=1b60d0cd-e691-440f-aa83-cc788b983d0c&pf_rd_r=WHJTWV7J842SEVSR758V&psc=1&refRID=WHJTWV7J842SEVSR758V
I'll have to crawl under my RV and see if there is a convenient place for something like this. The one drawback I see is access....seems like it would be a tremendous hassle anytime the battery needed to be checked/maintained/etc. If I was able to mount such a bracket, I'm not entirely sure how I'd be able to lift the battery up into it.
-Chris
That is why we went with AGM batteries, nothing to maintain.
I have a Harbour Freight Motorcycle lift I used to lift the box into place.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
