bcsslc
May 07, 2013Explorer
I can tell you this . DO NOT CUT A HARD 90* IN THE CORNERS!! Make sure you make about a 1" radius into the corners. It will prevent cracking. Most critical with a hard surface like fiberglass. Regardless please take my advice any roofing materials that take that kind of abuse will crack over time in the corners unless the are rounded.
Good luck
Good luck
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
