Jbrowland
Dec 12, 2016Explorer
Thanks for the input folks! I ask mostly because a Zamp brand panel is about 4x the cost of many others.
Zamp says this about my kit:
Deluxe 160 Watt RV Solar Kit, 30 Amp Deluxe Hardwired Solar RV Kit Contents –
160 Watt Class A Monocrystalline High Efficiency, Highest Quality Solar Panel
30 Amp 5 Stage PWM Digital Deluxe Solar Charge Controller
Digital display for voltage, current amps, and amps per period of time.
LED Lights indicate operational status and battery charge status.
25 Feet of High Quality Wire Properly Sized for up to 450 watt of solar power. Wire Connectors Included ( 2- Butt Splice Connectors, 2 – Ring Terminal Connectors)
Our wire is made of high quality and purchased from an American company – any wiring that needs to be done is wired at our Bend, OR shop.
4 – Solar Panel Mounting Feet (Nuts, Bolts & Washers Included)
1 – Inline 30 Amp Breaker
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
