MrWizard
Dec 12, 2016Moderator
you want to try and match the voltage specs
VOC..open circuit voltage
VMP..loaded working voltage
number of watts and amps can vary, just get the voltage as close as possible when paralleling panels
series connections are a whole different thing
and must use identical matching panels, because of the series amp flow circuit
a 3amp panel would choke a 6amp panel and there would be NO gain
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
