GENECOP
May 08, 2014Explorer II
The only consideration is the additional weight and the balance of the TT. A center above axle location is prefered....166 lbs....20 gallons of water...Pumping from the extra tank into the main is a good plan, unless you could sister the tanks together but location probably prohibits that....
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
