RUSSELL5000
May 29, 2015Explorer
Adding Additional Stabilizer Jacks
I have the TT in signature – a 2015 Jayflight 28BHBE – and I want to add additional stabilizer jacks – one on each side behind the axles toward the rear of the trailer and one on each side before the axles toward the front of the trailer – a total of four. I have used those screw type jacks in the past but that has become annoying.
MY TT has the enclosed underbelly. I can see one side of the frame clearly but the other side is covered by the underbelly material.
My question: is there any way to tell whether or not I am drilling through the bottom part of the I and into something that I don’t want to hit? My assumption is that if I can push up on the underbelly material far enough to slip a bolt through a hole I drill then I am fine; if I cannot push up the underbelly material then there must be something there (like a black water tank maybe?).
Does this make sense? Is there a better way?
Thanks!
Thanks!
