Hondavalk
May 08, 2014Explorer II
mleekamp wrote:
Instead of plumbing to my current tank, was thinking of adding a second pump and a hose to fill the factory plumbed tank. Use it as a back up to fill my tank only.
I bought a 34 gallon cooler that had a threaded drain port that I run through a 12volt pump to refill my freshwater tank. I have the cooler in the back of my truck so I can refill as often as needed.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
