doughere
May 09, 2014Explorer
I removed the original 30 gal fresh water tank that was mounted on the floor under the couch (certified as the most uncomfortable couch in the universe).
I "hung" 3 40 gal tanks between the trailer frame rails below the floor. 2 of the tanks are tied together to form an 80 gal tank, one is by itself. I have 2 hand valves to select which tank is used, feeding the original pump.
Removing the original tank gave me a nice under couch storage area, and the 2 tank configuration allows me to take on the right amount of water for whatever stay we are planning. I never travel with the 80 full, just fill when going into a campground.
Don't forget, you need to store that water. I added 2 extra grey tanks (again valved to use whatever is needed) to hold the extra water.
Regards,
Doug
Regards,
Doug
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
