burningman
Jan 02, 2017Explorer II
I wouldn't use less than a 10-gauge cord.
The transfer switch is perhaps the most convenient but it's another possible failure item.
The cheapest and arguably safest way is the outlet installed in or next to your original shorepower cord compartment, with wiring going back to the rear to a plug that goes into your generator.
You simply plug your shorepower cord into either the generator or the shorepower, there's zero possibility of ever cross-connecting both at same time.
That's something I like having full manual control over and easy visual confirmation of what is connected to what.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
