For those of you that added shelves to your bedside closet.....I can only screw into the sides, how difficult Will this be without going through the wall???
Use 1" x1" cleats glued and screwed with short screws into the closet walls. Or, if your closet walls are paper thin, just use glue and tape the cleats in place until the glue hardens. An alternative, if your closet walls are 1/2" thick or greater, is to use shelf pins. You should use a drill stop so the holes you drill for the shelf pins do not become a through hole in the closet walls. Shelf pins will be the cheapest way to support the shelves.
Along with the frame idea how about building what amounts to a book case with legs that transfer the weight to the bottom of the closet. It should be easy to attach it to a vertical surface in a couple of spots to avoid it tipping over.
thanks for all the ideas! I really wanted to go with the command hooks, since that plus wire shelves i could do on my own. but they are sooo expensive, and need close to 30...
In our previous camper, I added several shelves. I used the wire version from Lowe's, I cut the wire to the right length with a bolt cutter. Easy to do. When we sold the camper, I left them all there.
In my current camper, we are using self-standing wire shelves now, they stack on top of each other, so no drilling holes. Sorry, no photos of those.
Anytime you hang a shelf, that will have to support some weight, you need to be concerns about the "meat" of the support wood. There's not much of that in our Class C. Your's may differ.
But here are some suggestions: - build a frame. That's what I did for the shelves that sit next to the pantry in our wardrobe. There should be a post with pictures called "Pantry" in the Class C forum. - rip some wood down to 1x1" and attach it to the sides/rear of the compartment. Glue and screws. This will create a bracket for your (now unadjustable) shelf to sit on
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 03, 2026
