toedtoes
Oct 20, 2022Explorer III
My motorhome never needed it. The heat easily rose up the vent and out. The fridge never had reduced cooling even in high temps.
With my trailer, it is vented out the side. The fridge cooling capabilities are significantly reduced in high temps. The fans are absolutely required - I also put a reflective window sheet on the wall below the vent to reduce the external heat.
If you have a significant difference in the fridge's cooling capabilities depending on external temps, then adding the fan may help. If there is no difference, then the fan is unnecessary.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
