stripit
Oct 22, 2022Explorer
When we full timed in a Mobile Suites 5th wheel I installed 2 fans, one at the bottom area and one up top at the factory installed vent. This way I was sucking hot air and helping it extract out the top. We found before that if we were parked where the kitchen/refridge side was exposed to the direct sunlight and it got hot, the fridge was not able to keep the correct temps. I could remove the fridge exterior acess panel and either plug in or unplug as the need arose. I bought 2 square box fans about 4 inches across and they fit very well and had no noise we could ever hear.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
