Oct 23, 2022Explorer II
What temperature settings do you have on your fan thermostat?My factory installed thermal switch attached to the upper cooling fin is set at 130°F.
That switch failed open so I bypassed it with a manual toggle switch inside the lower side cover so I can manually turn the fans on when needed.
Running the two factory installed fans during the hot Texas summer makes a huge difference.
My fridge is mounted in a slide out so the fans are required for proper cooling in summer
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
