Cummins12V98
Oct 28, 2022Explorer III
My last DRV had the frig in the slide with the two vents on the slide outer wall. I cleared out all the loose insulation so it had a clear path from lower to upper areas. I then added a small computer 12V fan to the back side of the upper vent. I placed it on a 12V switch. The temp drop in the frig was remarkable!!!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
