SJ-Chris
Aug 12, 2023Explorer II
enblethen wrote:
I would not tap any wires. Power the fans up off the 12-volt Red and Black. Install a manual switch or route through small thermostat.
It is running through a thermostat. But as currently wired, the thermostat always has power, and if the temps rise enough (even if the refrigerator isn't on), the fans will go on....even if the RV is in storage. Yes, I can open the side panel and disconnect the power to the thermostat (...I have easy connectors on the power lines to the thermostat), but I'd rather just have it wired to the "Fridge on/off" power so that it will never be on if the fridge is not on.
-Chris
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
