fyrflie
Aug 13, 2023Explorer III
One thing I found this winter , when I replaced my frig cooling unit, was that the area above the fridge was not blocked off from the backside ventilation area. So any heat generated by the frig would rise up and fill that void, then eventually push into the coach.
Before I slid my fridge back in, I installed a piece of sheet metal to block off that void area and keep the heat rising up and out the roof vent.
My thought is that the efficiency of the refer depends largely on the removal of heat from around the cooling unit, so any effort made to assist that process can only help.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
