Joe Way wrote:
Depends on the duty cycle of the compressor compared to how you use it. The Tech Sheet for the Hadley 850/851 compressor has this spec: "Maximum cycle time 7 minutes with 30 minute cool down." If you have this compressor and can get your work done in 7 minutes, you should be good to go.
If you have a different compressor, research the duty cycle spec on it.
Thank you for that. Yes, It is a tiny little compressor and it does get hot. I wouldn't use it to inflate a flat tire or fill an air mattress. Just for topping off tires. Seems to work good.
