MrWizard
Jan 21, 2016Moderator
i anchored mine directly with screws
but since your going for a bigger hole
you might want to try a hollow cutter
a piece of stainless tubing the correct size, sharpened from the inside edge out
it other words a a round razor turning in your drill driver
cut the rubber not the under layment
then use a conventional bit to drill the hole
this way you don't run the risk of twisting the epdm roof material
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
