Bumpyroad
Jan 22, 2016Explorer
MrWizard wrote:
i anchored mine directly with screws
but since your going for a bigger hole
you might want to try a hollow cutter
a piece of stainless tubing the correct size, sharpened from the inside edge out
it other words a a round razor turning in your drill driver
cut the rubber not the under layment
then use a conventional bit to drill the hole
this way you don't run the risk of twisting the epdm roof material
that sort of sounds like what a plug cutter would do. intended to drill plugs out of a board to match the wood used.
bumpy
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
