RVcircus
Jan 28, 2016Explorer II
Bumpyroad wrote:
what might work is a type of well nut that BPS and other marine dealers sell to mount trolling motors on a flat surface. about 3-4 inches long rubber with a brass nut that when you tighten it down it mashes the rubber out and ends up being fairly secure. it has to be secure when you have a 40-80 lb. thrust trolling motor jerking it around.
bumpy
Do you know if the rubber creates a water tight seal?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
