djgodden
Feb 18, 2016Explorer
Well nuts do indeed create a water tight seal, provided you also slather up the screw itself. The EDPM roof bunches a little as the rubber of the wellnut compresses and deforms (as it should). I didn't have any problem with the EDPM roofing twisting along with the drill bit. Just cleanly sliced right through it. I used a 1/2 wood bit at high speed. No worries, easy peasy.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
