kfp673's avatar
kfp673
Explorer II
Jul 17, 2020
Anyone use Quick connect for water hose?
As the title says, I am interested in the idea of leaving a quick connect on the water hose for our travel trailer. We have a small plastic door that has a plastic connector which is again threaded to another connector in the camper. Sorry for the vague terms. I believe what is mounted from factory is 1/2" male to 3/4" female, and that 3/4" female is what the hose connects to. 1- I would like to replace that factory adaptor with a metal one (although the rest of the system is plastic anyway so not sure it matters) and 2- I'd like to leave a threaded quick connect on the camper and on the hose. Because this connection is recessed, it's often difficult to get the hose tight enough to avoid leaking and even spraying out. A quick connect would lave that portion connected and make it easy. Anyway, I see these all over Amazon. Is anyone using them for RV's? and if so any suggestions? Thanks!
  • kfp673 wrote:
    Thanks! Do you have a link to the one you used? I like the one iamichabod shared but want to review all.
    Also, I noticed they make them in reverse where the male end would attach to the camper instead. Cant seem to find dimensions listed on any though so it's touch to tell which would fit better. click
    Thanks again!
    If you click on the small image just below the main image on the link you posted (and most of the other sites linked) you will find one of them has the dimensions of the adapters. Looks like they are all about 1.43 inches long. I use the same ones on all our hose fittings, both at home and on the camper. My camper has the male end attached to it and the female end on the hose. The other end has the male end attached to a female adapter on the water filter and then more similar fittings to the hose bib.
    Barney
  • IB853347201 wrote:
    IAMICHABOD wrote:
    I like This one the male end fits better and is shorter than the other types. It may fit behind your door.
    I use quick disconnects on everything.
    X2
    X3... I went through several cheap plastic and brass plated QD's over the years that used a modified hose washer for the seal. Even the least amount of dirt or mineral buildup caused them to leak. The brass QD's linked use an independent O-ring as shown that seals well and can be sourced at most hardware stores if damaged. I have a small package of spare O-rings I found in the loose hardware section at an Ace Hardware, but I haven't needed to replace one yet.
    X2
  • ernie1 wrote:
    I did what you are thinking of doing and it"s worked out extremely well. However, one of the biggest problem in doing this is that most quick connect fittings are too long to fit under your plastic cover unless you drill a hole in it and that looks really hokey! I looked around and found the shallowest fittings I could find and swapped holes with the tv cable connection so that the hose connection would be towards the center of the plastic cover where there is a bulge and it fits and works well.
    Thanks again!
  • rhagfo's avatar
    rhagfo
    Explorer III
    MarkTwain wrote:
    Just be sure and use the white plumber tape for the quick connect connectors.
    Hose connectors are sealed with a rubber washer, not at the threads, Teflon has no effect.
  • Just be sure and use the white plumber tape for the quick connect connectors.
  • I like This one the male end fits better and is shorter than the other types. It may fit behind your door.
  • I did what you are thinking of doing and it"s worked out extremely well. However, one of the biggest problem in doing this is that most quick connect fittings are too long to fit under your plastic cover unless you drill a hole in it and that looks really hokey! I looked around and found the shallowest fittings I could find and swapped holes with the tv cable connection so that the hose connection would be towards the center of the plastic cover where there is a bulge and it fits and works well.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Jan 08, 2023
