Bumpyroad
Mar 18, 2014Explorer
if your main/only issue is with sediment, just use a cotton string type of filter or similar type which should have a much better flow rate than the "sterilizing" ones. my first filter setup was a roughing filter first then a sanitizing one and had such a slow flow rate that I switched to two filters in parallel and got decent flow.
bumpy
bumpy
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 13, 2026
