Bumpyroad
Mar 21, 2014Explorer
S'more campers wrote:
Doubling up on your filters (parallel) would significantly increase the beta rating, reducing wait times at the fill station. Probably a bit of a pita to setup, but better than being 'that guy' at the fill station.
actually it was easy to set up and once set up I just left it intact and installed it like any single filter in the hose water supply. the only issue was getting a reversed wye connector with double input and single output.
bumpy
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
