- woodsmitchExplorerThanks BarneyS! That is what I was looking for. I have used deflappers that I have bought for years but wanted to try these out to see if they would work better.
- tvman44ExplorerI use 2 of Camco's large deflappers. :)
- robatthelakeExplorerI built some Years ago,but used the wrong type of Pipe! Too heavy and nearly impossible to grip the fabric!
Be sure not to use schedule 4 or whatever the a good PVC pipe is called in Your part of the World!
Simple to make ! 18 Inches of Light weight PVC Pipe .Run the pipe through a Table Saw to slit one side. Drill two holes part way in from both ends . Run a SS Eye Bolt with SS Washers and a SS Wing Nut through the Holes ! clamp down on the fabric and attach the eye bolts to the Awning Rafters with Bungee Cords! - moonlightrunnerExplorerI think there are two types of awning deflappers.
and awning "supports"
I suspect the second "deflapper" is what the OP is looking for. Sometimes, you don't want to BUY BUY BUY stuff. Sometimes, you prefer to build your own. - tvman44ExplorerPictures of these homemade De-flappers would be nice. :)
BarneyS wrote:
Those things are so inexpensive to buy I can't see why anyone would want to make their own or re-invent the wheel.
Barney
x2 -- I got the deluxe version and thin I paid $14.00 a pair??? Maybe $19.00- BarneySNomadThose things are so inexpensive to buy I can't see why anyone would want to make their own or re-invent the wheel.
However, this thread may be the one you are trying to find.
Barney
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
