agesilaus's avatar
agesilaus
Explorer III
Jun 05, 2014
Awning fabric replacement
This is for an A&E awning
My awning fabric was shot. So I went to eBay and bought replacement fabric for $119. The package arrived fairly quickly and the fabric looks to be sturdy. Apparently it doesn't matter what the width is, ours is narrow at 13 feet but all the way up to 18 feet is the same price.
The instructions may as well be written in Sanskrit tho. No drawings and the instruction tell you to clamp the vice grips on the frabbit tube and so on.
So go to youtube and watch this:
Tutorial
There are three or four videos up on YT showing how to do it. I ended up watching two different ones which cleared up some of the mystery from the first video.
It tells you most of what you need to know. My awning was a little different tho and there is no hole to stick a screwdriver in on mine. Watch the video you'll figure that out.
Be absolutely certain to use a marker to mark every single piece of the awning hardware: Right side part , Left side part 3 and so on. Stick some tape on the part andf write on that if you don't want to mark up the hardware. We found out that the right and left side parts are not interchangeable and you will be working a very irritating puzzle if you have to figure it out later. The arms are different length on our Titanium which led to the parts confusion.
Also note which way: clockwise or counterclockwise that the spring unwinds.
Otherwise it goes fairly fast and isn't hard, You'll need quite a few tools to but the video lays them out for you. The eBay fabric is the same on both sides which means it doesn't matter which side ends upwards. Three people are really needed for parts of this.If you have everything you can probably do it in 2 hours.
  • mobilefleet wrote:
    if you are having to take all those tools out and remember revolutions and messing with ratcheting and removing the spring and end caps and all that, you are doing it the hard way. Easiest way is to let out awning only 3 inches or so, then let the arms out of their clamps and rest on the ground. next unbolt the arms from the awning rail at the top and remove the one or two screws that hold the awning from shifting in the drip rail. Grab the awning arms with one person on each arm and slide awning out of rail and place on sawhorses. Then drill out rivets on the non-catch end (end without the release lever) and pull the cap back only enough to slide off the old fabric. usually don't even have to remove the roll pin on that end. Then install new fabric and wrap it around tube and put new rivets in end cap. Last (with helper or two) guide fabric back into rail, reinstall screws and top brackets, and put arms back into bottom clamps. done. By letting awning out only a few inches you are avoiding having to mess with springs and tensioning.
    Basically that's what we did but there were complications. Somewhere down some road we lost one of the inner arms with the slider. And where we have the rv parked there isn't enough room to work right next to the rv so we had to move everything to another spot.
  • if you are having to take all those tools out and remember revolutions and messing with ratcheting and removing the spring and end caps and all that, you are doing it the hard way. Easiest way is to let out awning only 3 inches or so, then let the arms out of their clamps and rest on the ground. next unbolt the arms from the awning rail at the top and remove the one or two screws that hold the awning from shifting in the drip rail. Grab the awning arms with one person on each arm and slide awning out of rail and place on sawhorses. Then drill out rivets on the non-catch end (end without the release lever) and pull the cap back only enough to slide off the old fabric. usually don't even have to remove the roll pin on that end. Then install new fabric and wrap it around tube and put new rivets in end cap. Last (with helper or two) guide fabric back into rail, reinstall screws and top brackets, and put arms back into bottom clamps. done. By letting awning out only a few inches you are avoiding having to mess with springs and tensioning.
  • Funny, I just got the same one and the instructions were pretty good as far as how to attach it to the roller.
    Not much beyond that though.
  • So you aren't familiar with the frabbit tube I take it. Just be careful that the frezmeter doesn't get flob strobed as that can cause problems.:B
