GordonThree
Jul 16, 2019Explorer
ependydad wrote:GordonThree wrote:
48 volt. The higher the voltage the better. It will give the most margin between "full" and "empty".
With the lithium batteries, does that reasoning still stand? The drop-off for lithium is sharp with very little in the middle of charged vs. not.
Yes, applicable to any technology. On lithium you can't rely on voltage as an accurate state of charge indication, because of that flat discharge line. However having more margin is still a positive.
Counting amps out vs amps in is even more important, IMHO.
Higher voltage also lends itself to more efficient conversion inside the inverter. Instead of having to amplify a 12v source with a gain of 10x to get 120v output, a 48v source only needs to be amplified 2.5x (this is over simplified but works as a demonstration). The amplification (boost) causes heat in the inverters's transformer and switches (transistors). The less work they have to do, the less heat they generate.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
