jornvango's avatar
jornvango
Explorer II
Dec 23, 2018
Battery down to 9.7v ??
We have one 12v battery in a travel trailer. After driving for 5-6 hours on Friday, we boondocked in Texas. 40s at night, 50s during the day. We only used 1 led light in the evening and the water pump a few times. The fridge is on all the time (battery/propane).
Yesterday Saturday, in the morning when we used the water pump, it kept rattling away as if it didn't have enough power. Fridge and lights worked.
We plugged in the portable 100w solar panel. The charge controller read 9.7v! After a few hours of solar charging, it went up to 12.2v but by the time the sun set, it showed 11.57v even though nothing but the fridge was on in the camper.
This morning (Sunday), when we plugged in the solar, it read 9.7v. Water pump kept rattling away after we washed our hands and the led lights were dimmer with the pump on.
Some facts:
- flooded battery dated 2013
- type marine (it shows cranking amps on the label)
- fluid level is ok
Is the battery dead / beyond repair? How come the fridge and lights still work?
Based on my limited knowledge, a battery shouldn't be below 12.3v ... Based on the past experiences, one night of light usage after driving, the battery should still be around 12.6v...
  • midnightsadie wrote:
    its time for a new battery. anything under 12.8 is not good and its 5years old.
    A fully charged flooded battery with no load on it should read in the 12.72 volt range, under load voltage will obviously drop, and the greater the load the greater the voltage drop. One can easily see voltage drop into the high 11s under heavy load but once that load is removed voltage will bounce back. Ideally you don't want to draw a flooded deep cycle battery down any more than ~ 50%, meaning it's unloaded voltage should drop no lower than ~ 12 to 12.1 volts. From the OP's description it would seem his battery is due for replacement.
  • its time for a new battery. anything under 12.8 is not good and its 5years old. buy a deep cycle marine battery even a wal mart will do a good job, I,ve got two wal marts in my MH that are six years old and still going.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: Jun 07, 2026
