EsoxLucius's avatar
EsoxLucius
Best acoustic material for gen set
I have room to add acoustical material around my Onan 3600 KY generator. The compartment and generator will accommodate 1/2" and 1" material, depending on location around the unit. Clearances and venting requirements per Onan installation manual will be observed. That said, what is the best acoustic material to use that has a 200 degree self-extinguishing rating. Rigid sheets are preferable. I found the appropriate adhesive. Thanks for your help.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jan 18, 2025
