Vintage465
Aug 04, 2023Nomad
Best Atwood Stove Mod Ever!
Since the existing Atwood Piezo sparker tends to work only when it likes to. I converted mine to an electronic unit sourced from gas grill replacement. My brother did this to his trailer and I pirated it from him. I used a step bit to enlarge the existing hole so the new pushbutton igniter assy would fit. All the wires and igniters in the kit are discarded. And I had to order up a set of 5 wires to get one that I needed to get to the oven pilot. A very simple bracket needs to be made to attach the igniter to the oven pilot. I used the existing ones from the stove.....I had to love on the connector with needle nose pliers a bit to get them to fit the new ingiter, but worked very fine. It worked the first time with no tuning or adjustments. I think this is a very worth while and inexpensive mod. All you have to be is reasonably good with your hands. I don't think i spent more than 2hrs doing this.
Grill Igniter kit
Igniter wire and electrode kit
Note: Moderator edit to fix long URLs which made page too large.
Grill Igniter kit
