Jerrybo66
Sep 10, 2013Explorer
You sure have yourself a project. As a thought. You mentioned that the walls were mushy from water leaks. Also you topped the floor with USB and it was insulated with a metal underbelly. My concern would be how much moisture got into the flooring & underbelly. Can it be vented enough to completely dry out before covering it with new material, possibly starting the rot on your new work. Anyway, just a thought. Good luck..We'll be watching for your progress..
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,411 PostsLatest Activity: Jun 25, 2026
