Velislide
Sep 10, 2013Explorer
Jerrybo66 wrote:
You sure have yourself a project. As a thought. You mentioned that the walls were mushy from water leaks. Also you topped the floor with USB and it was insulated with a metal underbelly. My concern would be how much moisture got into the flooring & underbelly. Can it be vented enough to completely dry out before covering it with new material, possibly starting the rot on your new work. Anyway, just a thought. Good luck..We'll be watching for your progress..
The original subfloors were all in great shape, minus the 3-4' area that I cut out, reinsulated and redid the floor joists. I'd imagine the subfloors would have been rotten by now if there was a lot of moisture in there, but they were dry and in great shape. I'm sure this campers been sitting for 10+ years without any activity.
All I can do is hope I suppose! Worst comes to worst, I can fix areas that need attention, will be much easier then reconditioning a full 36' camper, all at once.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,411 PostsLatest Activity: Jun 25, 2026
