- HoustedExplorer III
PaFruMan wrote:
@ Housted I guess u mean 12400 lbs so 5.6 to right? (We Europeans work with metric units...)
Lifting the whole RV just for $2000 is great!
Have u noticed some stability problems. I read in some forums that, lifting the whole vehicle by jacks at remote places can cause a permanent deformation of the frame.
Paul
I have a Northwood 5er which has a very substantial frame. I have not noticed any stability problems using the leveling system. We have been in campsites that had one side off the ground and the wheels would turn freely. No problem. Yes I meant 12400 pounds. I modified the system to turn off the back jacks with a push button, so when I use the remote to hook/unhook I use the all up/all down buttons to raise/lower the pin.
Housted - 93Cobra2771ExplorerJust thinking out loud - I suppose, ideally, if you put jacks in front of your tires, and behind your tires, and then used the tongue jack on the front like normal, frame deformation would have to be pretty minimal, Especially if you are only taking some of the load off the tires so your aren't bouncing as much, or minor leveling side to side...
- PaFruManExplorer@ Housted I guess u mean 12400 lbs so 5.6 to right? (We Europeans work with metric units...)
Paul - Argosy24ExplorerI also like to build things. I installed a manual leveling hydraulic system on my motor home. By the time you're done you will have moved so much, made so many parts, brackets, reinforcements, hydraulic or electric lines, anything prefabbed won't detract from satisfying your need. It's a big job.
PaFruMan wrote:
@Housted:
How heavy is your RV? And are u only stabilizing it or can u lift your vehicle to change tyres for example?
Paul93Cobra2771 wrote:
And, if you don't mind my asking, what did that system cost you?
Total weight is about 12400#
Yes I can lift all four wheels at once. NOT just stabilization.
Got a deal on the system at about $2000.
Housted - 93Cobra2771ExplorerAnd, if you don't mind my asking, what did that system cost you?
- PaFruManExplorer@Housted:
Paul - jcsbExplorerYour question as to one or individual hydraulic resevoirs.
Bigfoot offers both. - PaFruManExplorerThanks a lot Housted,
this is exactly i was looking for. That means my assumtions were right.
Does anyone else has examples like this?
Paul - HoustedExplorer IIII have the Reico Titan Ground Control System (electric) It has a 60 amp main fuse and a 40 amp fuse in both sides of each motor. Never blown one!!
See setup here --> Control setup
Works well and can lift the whole rig off the ground to service all four wheels at the same time.
Housted
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,420 PostsLatest Activity: Sep 22, 2026
