Ductape_Dave's avatar
Ductape_Dave
Can Foam Cushions be Glued Together?
I have a dinette which I stack pillows against the wall to form a triangle to lay against when watching tv. The pillows constantly slide out and I was thinking about making a triangle wedge to place in the dinette to create a lounger, wanted to know if foam cushions can be glued together so I can cut the large wedge I need?
Thanks for any feedback!
Dave
  • Naio wrote:
    I've used the stuff Old-Biscuit refers to. It's not cheap, and for my project I think I would have saved money just going to an upholstery supplier and having them custom-cut foam to the shape I wanted.
    It was one of those 'seemed like a good idea at the time' projects.
    X2!
    By the time you buy foam, glue and covering plus your labor you would be further ahead to simply buy a premade foam triangle pillow or "wedge"
    Can be had for $40 and up and delivered to your door!
    Here is a search at Amazon..
    TRIANGLE PILLOW SEARCH
  • Naio's avatar
    Naio
    Explorer II
  • Foam Spray Adhesive......
    GO to craft store (Hobby Lobby, Michaels, Walmart etc.)
    Get the type of adhesive for the type of foam you are gluing together
    Open-cell, closed-cell etc.
    Spray both pieces and then press then together.. Foam adhesive gets tacky quickly.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
