cannesdo's avatar
cannesdo
Carpet installation question...
I'm replacing the carpet in my fifth-wheel. I have a memory foam pad and am trying to visualize how this all goes together.
Do I need to use a knee-kicker/stretcher for such a small space? (longest piece is 16' but only a few feet wide)
They said the pad should be glued to the floor but I'm not using toxic products so I'm opting for tape. But on top of the pad, between that and the carpet do I need tape there also? I've read you tape there too. Seems if you have tape on it and set down the carpet the kicker will be working against the tape. I would think that just having the pad stuck to the floor would be enough. Then stretch the carpet over it and tack it down with a stapler and I'll be good to go -- no?
And since it's a thick pad (1/2" memory foam) I'm thinking leave a little space at the edges as I'm not sure the staples will go through the pad and sufficiently tack the carpet to the floor. Then again it does compress. ? I'm definitely leaving room where the slides come up and over the center part of the floor. Cutting the pad short there.
Not using tack strips. Don't have them under the carpet I have now.
Any tips would be appreciated. Everyone seems to do this in a slightly different way.
Thanks!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
