suprz
Apr 01, 2018Explorer
Changing outlets
Has anyone changed their regular AC outlets to the ones that also include USB outlets? If so what brand and how do you like them?
Blacklane wrote:
They're certified by both the Underwriter's Laboratory and CSA for use in RVs. That's not true of devices with screws to hold the wire connections.
kellertx5er wrote:Blacklane wrote:
If you replace the device with a residential one, you need to install a box, which is rarely possible, and you need to avoid the use of screw connections, which can loosen under vibration.
So you suggest using the 'stab-in' connections instead? No thank you.
Blacklane wrote:
Note that RV electrical devices (such as outlets and switches) are different from residential devices. They are self-contained, meaning the wires are punched-down and the protective box is integral to the device. The reason for that is (1) to save space and weight, and (2) to create a vibration-proof electrical connection. (Many will say that it is to save time and money, but in my experience they cost more and take longer to install than residential devices, plus you need a special tool to do it).
