suprz's avatar
suprz
Changing outlets
Has anyone changed their regular AC outlets to the ones that also include USB outlets? If so what brand and how do you like them?
    Typically manufacturers use speedbox duplex receptacles so for easiest installation the trick would be sourcing a version that includes USB ports. Not worth the expense or effort IMO when one can simply plug in a stand alone USB charger.
  • DrewE wrote:
    Something like this that mounts onto an outlet might be more practical. You wouldn't be able to use the securing screw, most likely, since the self-contained outlets don't have a central screw hole for a cover plate.
    As to your actual question, I don't have any personal experience or particular recommendations.
    that is what I use in my s&B and the outlets in the s&b are a lot easier to work on than those in the rv. but a simple single plug in USB adapter works just as well.
    bumpy
  • DrewE's avatar
    DrewE
    Explorer III
    RV outlets commonly are self-contained wiring devices (meaning they don't have a separate electric box). If you have access and space and wire slack to install a box and a traditional outlet, it should be relatively straightforward to put in one with a USB charger; but lacking any one of them and it would be a rather tricky job. I haven't happened upon any self-contained ones with USB chargers built in, though I must admit I haven't really looked either.
  • Watch the current rating of the USB portion. It's often in the 1.2A range and not good for much.
