rickst29's avatar
rickst29
Charge Batteries from Tow Vehicle, using a Solar Controller.
This modification occurs in both the Tow Vehicle AND the Trailer. A Solar controller is required (with or without existing Panels).
In the Tow Vehicle (hereafter "TV"), a set of switch-Controlled Relays allow the Driver to choose between "24V" and "12V" operation on the Bargman "Trailer Battery Charge" wire. (The "12V" option is kept for the situation of towing other, unmodified Trailers.) When the "Mode Switch" is activated, the Relays switch the two legs of the Bargman "12V Battery Charge wire" (battery->fuse->Relay#1, Relay#2->Bargman Connector) so that a cheap 12V-to-24V DC Voltage Booster is engaged between the Relays.
In the Travel Trailer, another set of Relays does two main jobs. The first Relay detects that 24V is present, and switches a "coil input control" circuit for another Relay. The second Relay chooses between two power Sources for the Solar Controller: When 24V is not detected, the wire from Solar Panels is connected to the "Solar +" terminal. But, when 24V is detected on the Bargman, then the wire from the Bargman is connected instead. (Optional: a 3rd Relay, allowing a "12V" Bargman connection to connect the "Battery +" terminal. But I'll explain why you probably shouldn't do this.)
Cost with pre-existing Solar Panels and Controller (MPPT strongly preferred): $40 Booster device, four or five 5-pin automotive Relays @ $5 each, a "Mode Switch" for the TV dashboard ($10-20); and a "special" 4-pin Relay with 24V coil ($10). Total: $75-90.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
