rickst29
Apr 18, 2016Explorer
In my configuration, an MPPT Solar Controller can receive power from either the "genuine Solar Panels" (rated ~ 330W max, 5A @ 67V under prefect conditions) or the Bargman Input (rated ~ 290W max, 12A @ 24V under any conditions). Maximum power draw on my MPPT, in "Boost" mode, also corresponds to ~ 290W.
Under Good Sun conditions, I leave it running "genuine Solar". But, under clouds or sub-optimal conditions (night, early morning, dusk), I flick the switch - and it disconnects the "genuine" Solar Panels, switching over to the fake "24V Solar Panel" instead.
The Solar Controller monitors Battery State and adjusts output Voltage accordingly. A PWM controller could perhaps be used, but wouldn't take more than 14.4V (average) from the Voltage Booster, and might attempt to draw more than 12A while connected. That would be a 'Bad Thing'(tm), and blow a fuse inside the sealed Voltage Booster.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
