rickst29
Apr 18, 2016Explorer
GordonThree wrote:
Is 24v standard for all diesels, otherwise where does it come from?
DanNJanice wrote:
Good question, it is unclear to me what the OP is talking about. If you had a 24V system I could see using the solar controller as described. I just don't know what vehicles have 24V electrical systems.
Sorry guys - I left out something important. I just edited the first post, to explain that a cheap Chinese "12V-to-24V" Voltage Booster gets inserted into the Bargman wire path when the Relays engage.
TV Relay Coils disengaged: 12V mode, bypassing the Booster.
TV Relay Coils engaged (powered by output from the controller switch on the dashboard): 24V mode, Voltage gets increased by running the connection through the Booster before reaching the TV's Bargman connector.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
