Old-Biscuit
Oct 08, 2017Explorer III
We had the carpet replaced in living room and both living room slideouts (damaged)
Independent carpet installers...........cut old carpet out of slideouts.
Used it as pattern then had 'binding' done to cover edge (edge of carpet that hangs over slideout) and then installed it
Not any more expensive then normal carpet installation.......biggest cost was the new carpet
Sounds like 'local shop' doesn't really want the business...RV installs can be time consuming due to 'lack of working space' and all the fitting needing to be done
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
