mabryoso1's avatar
mabryoso1
replacing slideout motor
The large slideout motor on my 2005 south wind just broke apart.. the slide is in the full out position.... Have located a replacement on ebay... How hard is it to replace??? Can I do it in the out position? also any info on the lock lever and any thing special to watch for... Any information. on the replacement would be appreciated.......
Thanks in advance,
Mabry
mabryoso1
[email protected]
  • I'll check out that video because this is good to know. Always been my worry slide motor going out in the middle of nowhere.
  • the slide being in the out position really helped,I have a 2oo5 southwind and the motor is underneath the slide very easy to change out with no adjustments required. It took about 25 minutes to change,I also used a
    higher torqued motor that matched my old one ...worked great...
  • 2005 39L Fleetwood was a simple change once I got the slide out. saved me 1500 dollars.
  • Let us know how you make out with that. How it is relatively simple for you.
