- ccchuckExplorer
Big Katuna wrote:
My slide motor did not have any specs on it; just a part number.
same here - bukhrnNomadif you can DIY on yours, be grateful it's not a Forester, not DIY friendly, unless you have a large shop, a forklift, a hoist, and you are a trained mechanic, as to replace the drive gear requires complete removal of the slide-out, as there is NO access to it otherwise, oh sure you can see it but Remove & Replace is impossible otherwise. Luckily it was covered under the extended warranty.
- Big_KatunaExplorer III did the NAPA power window motor swap too; worked fine.
Its also used in most power seats.
Doug is RV Tech that has worked most of his adult life in the RV service business and often contributes to threads.
I'm all for saving money but I dont like gambling. It isnt worth it to me to save a few hundred and maybe get a motor that will fail early. - klutchdustExplorer II
Big Katuna wrote:
Back when I did my two I was told that there are different motors for different loads so using one with a different # might backfire and fail early.
I trust Doug Rainer's opinion and he said use the same one.
Motors have all the specs you need to know on their tag to find a duplicate motor if you are so inclined. Don't know who Doug Rainer is. If you are referring to the step motor, it has been in service for about 5 years now and doing fine. - Big_KatunaExplorer IIBack when I did my two I was told that there are different motors for different loads so using one with a different # might backfire and fail early.
I trust Doug Rainer's opinion and he said use the same one. - klutchdustExplorer II
ccchuck wrote:
Found the motor!
powerglide p/n 523143, no movement when power is applied, very greasy.
On ebay motor is 670+
The manufacturer didn't make the motor, they had someone else do it then they resell it. me, I would look up the specs in granger or Mc.Master carr . Is there someone nearby that rebuilds motors, another option.
I found out the 300 dollar motor used in quikee type retractable steps is the same motor they used in a Ford power window, it cost me 47 dollars at napa. Do some research and save some dough.
i just looked it up, it is a simple motor connected to a gearbox, the greasiness you experienced most likely is the gear box leaking. Not knowing your wrenching abilities I would take apart the gear box and check that first then research a motor for that. Have you determined it isn't jammed.
Found others at 399 complete if you want to go that route. Do a bigger search on e bay. - ccchuckExplorerFound the motor!
On ebay motor is 670+ - ccchuckExplorerwell I can't find the motors, none of the compartments underneath have a panel, nothing is visible under the couch - I am lost. :-(
- ccchuckExplorer
klutchdust wrote:
Knowing the make of your slide will help. Looking at some u tube videos there are different motor mountings but they all work the same. The first thing i think is to determine if it is jammed, so you need to find where to access the motor to manually turn it. Check out some of those videos. Some use a long crank accessible through a hole in the coach and some you need a gear wrench to turn the bolt on the motor itself. Before it just started clattering where there any other symptoms like getting slower or going in crooked..
No symptoms, I will report back anything I find, appreciate the help. - klutchdustExplorer II
ccchuck wrote:
klutchdust wrote:
There are gears in there and a worm drive. Possibly the shear pin holding the gear on sheared.
At least that's the way mine is set up. Do you have any of the original paperwork that came with the coach that would have some information on the slide out that we could look at. Or the model of the coach, i think there are diagrams online I could look at. They aren't that complicated and since it just clatters it makes me think the gear is jammed or stripped or loose, maybe just misaligned. mine had an issue with the bolts coming loose and the worm drive jammed.
I just looked up a similar model and it says that there is access to the slide out motor behind the driver's seat. You can turn the slide out motor manually with a 1/2 inch ratchet . I would investigate this possibility because it may unjam it . This is also the way to manually retract or extend in case of motor failure. Mine ratchets and clatters when it reaches it's furthermost pints, mostly when i am retracting, I guess it's a safety device. Also is anything jammed to prevent the slide from going out, I left my slide lock on and broke the moulding. Maybe something fell beside it. Gkids baseball bat rolling around almost ruined my day once.
I have not yet located my motor access - it is not behind the driver's seat, I plan to crawl under again tomorrow to see if there is an access panel. This is a greyhawk 30 gs, 2006 model.
EDIT I will also check to see if any of the storage bays under the slide out offer access.
Knowing the make of your slide will help. Looking at some u tube videos there are different motor mountings but they all work the same. The first thing i think is to determine if it is jammed, so you need to find where to access the motor to manually turn it. Check out some of those videos. Some use a long crank accessible through a hole in the coach and some you need a gear wrench to turn the bolt on the motor itself. Before it just started clattering where there any other symptoms like getting slower or going in crooked.. Yes, sometimes accessible under the bays according to the videos.
38,780 PostsLatest Activity: Jul 20, 2026
