klutchdust
Aug 25, 2017Explorer II
ccchuck wrote:klutchdust wrote:
There are gears in there and a worm drive. Possibly the shear pin holding the gear on sheared.
At least that's the way mine is set up. Do you have any of the original paperwork that came with the coach that would have some information on the slide out that we could look at. Or the model of the coach, i think there are diagrams online I could look at. They aren't that complicated and since it just clatters it makes me think the gear is jammed or stripped or loose, maybe just misaligned. mine had an issue with the bolts coming loose and the worm drive jammed.
I just looked up a similar model and it says that there is access to the slide out motor behind the driver's seat. You can turn the slide out motor manually with a 1/2 inch ratchet . I would investigate this possibility because it may unjam it . This is also the way to manually retract or extend in case of motor failure. Mine ratchets and clatters when it reaches it's furthermost pints, mostly when i am retracting, I guess it's a safety device. Also is anything jammed to prevent the slide from going out, I left my slide lock on and broke the moulding. Maybe something fell beside it. Gkids baseball bat rolling around almost ruined my day once.
I have not yet located my motor access - it is not behind the driver's seat, I plan to crawl under again tomorrow to see if there is an access panel. This is a greyhawk 30 gs, 2006 model.
EDIT I will also check to see if any of the storage bays under the slide out offer access.
Knowing the make of your slide will help. Looking at some u tube videos there are different motor mountings but they all work the same. The first thing i think is to determine if it is jammed, so you need to find where to access the motor to manually turn it. Check out some of those videos. Some use a long crank accessible through a hole in the coach and some you need a gear wrench to turn the bolt on the motor itself. Before it just started clattering where there any other symptoms like getting slower or going in crooked.. Yes, sometimes accessible under the bays according to the videos.
38,782 PostsLatest Activity: Sep 10, 2026
