ccchuck
Aug 25, 2017Explorer
klutchdust wrote:
Knowing the make of your slide will help. Looking at some u tube videos there are different motor mountings but they all work the same. The first thing i think is to determine if it is jammed, so you need to find where to access the motor to manually turn it. Check out some of those videos. Some use a long crank accessible through a hole in the coach and some you need a gear wrench to turn the bolt on the motor itself. Before it just started clattering where there any other symptoms like getting slower or going in crooked..
No symptoms, I will report back anything I find, appreciate the help.
38,782 PostsLatest Activity: Sep 10, 2026
